Post new topic Reply to topic  [ 7 posts ]
 Post subject: PAIR removal 04-06?
 Post Posted: Mon Apr 02, 2012 10:13 am
Any how to's for removing the PAIR system on an f6 Hornet
Im in the middle of doing valve shims (36k) so i figure while i have it bits i may as well take it out.
Cheers Neil
 Post subject: Re: PAIR removal 04-06?
 Post Posted: Mon Apr 02, 2012 10:36 am
I think this is the system on my bike?
http://www.ronayers.com/Fiche/TypeID/26 ... TROL_VALVE
Also what are the Sub-Air cleaners actually used for?
http://www.ronayers.com/Fiche/TypeID/26 ... IR_CLEANER
 Post Posted: Mon Apr 02, 2012 12:03 pm
What it says on the tin. Filters the air that is breathed in through the PAIR system.
Speaking of breathers, a filter on the crankcase breather is a good idea, if it has been disconnected from the air box and vented straight to air. Possibly not so much an issue on a multicylinder engine, but there will be points on the four stroke cycle where air is sucked back through this breather, possibly bringing muck into the engine.
 Post Posted: Mon Apr 02, 2012 2:02 pm
[quote="buff5015"]I think this is the system on my bike?
http://www.ronayers.com/Fiche/TypeID/26 ... IR_CLEANER[/quo
The sub filter is imortant and make sure they are changed every couple of years. IF left for a long time they turn to a power substance and then clog up what it is keeping clean. Oldgit
te]
 Post Posted: Mon Apr 02, 2012 6:11 pm
[quote="oldgit919"
The sub filter is imortant and make sure they are changed every couple of years. IF left for a long time they turn to a power substance and then clog up what it is keeping clean. Oldgit[/color]te][/quote]
What if there is no air getting to my sub airfilter because the hole supplying it is bunged up with a rubber plug at the airbox.
Do I need to worry?
 Post Posted: Tue Apr 03, 2012 10:18 am
So to remove the PAIR system do i have to block off all the feeds from both of the above systems?
Does disconnecting the Sup Air valve give any electrical faults?
 Post Posted: Tue Apr 03, 2012 1:14 pm
Huckero wrote:
[quote="oldgit919"
Do I need to worry?[/quo
Well the valve vent solonoid wont work correctly will it? Honda put it there for a purpose i.e to clean the air going through. Oldgit
te]
