 Post Posted: Wed May 30, 2012 12:10 pm
Hi
I balanced my carbs at the weekend, and was just reading up on the PAIR valve removal.
From what I understand, I just need to take it off, make a blanking gasket, and re-fit?
However, that's not my main question...
From what I've read on here, Cylinder 2 is the vacuum for the tap, Cylinder 4 the vacuum for the PAIR valve, but my Cylinder 4 vacuum point was blanked off, the PAIR valve is still on the front of the block though.
What would this do?
 Post Posted: Wed May 30, 2012 12:27 pm
No4 cylinder is the one on the Right as you sit on the bike 8o
 Post Posted: Wed May 30, 2012 4:43 pm
Yup, and this had a 2" Length of hose with a screw in it, not a pipe for the PAIR, I didn't realise until putting it back together, when I've replaced the hose with one for my scottoiler.
What are the consequences of having no vacuum to the pair valve?
 Post Posted: Wed May 30, 2012 5:35 pm
means your Pair vacuum valve is dissconected! just remove the rest of the Pair and you
have it sorted 8o
 Post Posted: Thu May 31, 2012 9:30 am
Ah! Nice one. I have to remove the exhausts for that? Sounds like snapping studs to me. I'll just leave it!
Users browsing this forum: Bing [Bot] and 0 guests
