Board index » The Lighter Side » Geeks Corner
Post new topic Reply to topic  [ 2 posts ]
 Post Posted: Tue Jun 28, 2011 11:46 am
Chain Fooker
got a hp 1660
colour cart is fine black and white is low but ok for now
come to print some text using wordpad - pasted it in and print and nowt
tried a test page - no prob - colours came through even tho its set to black and white.....
tried notepad and got same thing
pasted my text in here and post message and will print no problem
any ideas why it shits itself if you use word or notepad???
gimme cake gimme it now
 Post Posted: Tue Jun 28, 2011 12:28 pm
I've come across this before.
Firstly are you using XP?
If I recall correctly you need to make the printer your default printer even if you select it when you print the job.
Failing that update the driver which is located here http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?cc=uk&lc=en&dlc=en&product=3811075
In addition you might want to try changing the colour of your text to blue, even though it prints the test page in B&W this will rule out a comms/driver error if it prints in say blue.
Hope this helps.
