Board index » The Lighter Side » Waffle
Post new topic Reply to topic  [ 1 post ]
 Post Posted: Fri Feb 08, 2013 4:43 pm
1. Set up an account with Photobucket http://www.photobucket.com/ or a similar image-hosting service
2. Upload your pictures from your PC to it
3. Copy the image link that will be generated for the picture
4. click on Img (above the box where you post) and insert the entire link between the symbols
5. Submit your post
If your picture is too big, either use Photobucket to reduce the size, or use the RSimg link above instead of the Img one.
We do prefer you to reduce the size of the picture, unless you need it bigger to clearly demonstrate a point
Users browsing this forum: Google [Bot] and 3 guests
