 Post Posted: Thu Aug 14, 2014 4:08 pm
Hi all
I have recently had to install a new set of sprockets and chain, since then I have noticed that the front and rear sprockets are ever so slightly offset (not completely in line with eachother). Can't get a photo right now but I will post one tomorrow, for now please excuse my Microsoft Paint illustration :lol
Is there something I'm doing wrong? I had to replace the two front engine mount bolts last year, as the previous owner had some dodgy bolts holding it in place. That was a bit of a challenge as the mounting holes didn't quite line up with the engine as you would expect..could the engine not be properly mounted in the frame?
 Post Posted: Thu Aug 14, 2014 4:14 pm
some rear sprockets are off set to one side! they have to be mounted the correct way
 Post Posted: Thu Aug 14, 2014 4:22 pm
Thanks mate I'll give that a check in the morning. I know that the front isn't, but I'll check the rear anyways.
 Post Posted: Fri Aug 15, 2014 2:41 am
Unfortunately there's nothing I can do to change the rear sprocket either. Front sprocket is identical on both sides, have to mention they're JT sprockets as well with a DID 520 chain.
 Post Posted: Tue Aug 26, 2014 9:57 am
how about customizing spacers? or washers? will it help?
Users browsing this forum: No registered users and 3 guests
