 Post Posted: Wed Mar 18, 2015 8:09 pm
Hi all
I am a new member, recently bought a hornet 250 1998.
Two days ago suddenly the speedometer, odometer and distance interval stopped working, where and what should I look into first to troubleshoot problem? Plan to open it up coming weekend....
I am also planning to replace the spark plugs with NGK iridium ones but was not sure if CR8EH-IX or CR9EH-IX should be used??? I'm located in Auckland, NZ where the temperature is between 0 - 18 degree Celsius in winter and 15 - 25 degree Celsius in summer
Thank you so much
 Post Posted: Thu Mar 19, 2015 12:35 am
That was some break!!!
The speedo cable is driven by a small plastic connector that fits over the drive sprocket securing nut.
It's lightly that the plastic connect will be worn and not turning the speedo cable.
Pretty sure I use CR9EH-IX plugs for my 250.
Hope your enjoying your bike, the 250's are terrific little machines.
 Post Posted: Thu Mar 19, 2015 1:39 am
Try This
viewtopic.php?f=59&t=25983
i have been using CR9EH-IX, no prob at all :)
 Post Posted: Thu Mar 19, 2015 5:18 am
Woaaa...thank you so much for the replies to both of you guys kenny & KANE :D okay i will look it up and let you guys know the update
Okay CR9EH-IX it is then..
Yup so far I enjoyed the hornet so much, traveling around 50kms everyday on & off motorway plus traffic filtering LOL
Ohh... I had a problem with fuel petcock or tap, the engine was loosing power and stalling like it was running out of petrol then found out the problem was the tap. I kept it midway between OFF & ON and no problems so far
 Post Posted: Sun Mar 22, 2015 1:38 am
You guys were right, the plastic joint is used up already. just like in the previous picture :clap
Ordered new one from honda for nz$14. will be delivered next tuesday :D
THANK YOU ALL
