Post new topic Reply to topic  [ 12 posts ]
 Post subject: Wet Plugs
 Post Posted: Tue Dec 01, 2015 4:57 am
Its not starting but i see smoke coming out of the pipe, white smoke
removed all plugs and they were wet, petrol
cleaned them and burned and put them back on.. still smoke coming out but not starting :help
no airfilter block
new battery
wet plugs, iridium plugs
Should i change plugs?
any help would appreciate a lot :ill
 Post subject: Re: Wet Plugs
 Post Posted: Tue Dec 01, 2015 8:31 am
Start with the basics, do you have spark?
Test the plugs by spinning the engine over with the plugs out but connected and resting against the engine.
Do you have a nice bright spark on each?
Check the choke connection - is it activating the choke fully.
If so check the radiator, take the cap off and check the fluid for any signs of oil.
You could try adjusting your tickover setting up & down as that might help if it's carb related issue.
That I think is all the easy stuff.
After that it's carbs off for a clean out & /or compression tester on the engine. If you have a compression tester to hand then do that after testing the spark plugs anyway.
 Post Posted: Wed Dec 02, 2015 1:05 am
did the basics but no luck!
eveytime plug are wet... :(
 Post Posted: Wed Dec 02, 2015 9:36 am
is the battery fully charged, new plugs?, is the choke jammed on 8o
 Post subject: SOLVED
 Post Posted: Thu Dec 24, 2015 2:34 am
nope
new bat. not new but clean iridiums and choke was fine :clap
======>>>>> >>> >> > Solution :mic
Thanks for Internet :clap
let me Share what i just did,
1. take all pulgs out, clean them (no need to burn their tips) and do not install
2. Disconnect the main fuel line (goes from tank to carbs)
3. Disconnect the other valve(small) goes out from the fuel tap and close/block it with a small screwdriver or nut(don't let air go in)
4. extra: i also cleaned all plug wires, disconnected from plugtops and clean the end of wire or you can cut 2, 3mm from the end of the wire
5. this is important, while plugtops hanging out of the engine, start your engine 8-10 times :puke
6. install plugs, plugtops, fuel line.. everything..
7. start your engine :hat
after this i found my bike start early in the morning without choke.... it doesn't die, i keep 1min or 2 idle then everything fine
it's like new life in the bike... i think clean plug wires did the trick
cheers!
 Post subject: Re: SOLVED
 Post Posted: Mon Mar 21, 2016 12:51 pm
nope
cheers!
you mean remove the plugs and remove the caps - start engine 8 - 10 times? now that is to clear excess fuel on the spark plugs chamber?
i'm also having a problem with my hornet, there was a leak on carbs, so cleaned carbs put them back on and started fine, but with small leak,
removed carbs check for leaks used threebond gasket on float bowls install back carbs and started fine, but still with very small leakage
removed carbs for the 3rd time found out that leak is coming from the top, old or previous owner used epoxy to seal leakage, used epoxy and leaks are gone, now install back carbs and bike doesn't start anymore
 Post Posted: Fri Dec 23, 2016 3:58 pm
my bike is now starting, i just need to set the right a/f mixture, i need brown tip on spark plugs, i guess my mixture is too rich
do i turn the a/f screw counter clockwise to let more air in?
 Post Posted: Sat Dec 31, 2016 2:11 am
Yes, doesn't it work for 2.5 turns out? that is what i have
but my mechanic had a different set up, it was not all same turns out but i set them all 2.5 turns out. i think it may burn more gasoline than mechanic's but it doesn't really matter :D
 Post Posted: Thu Feb 23, 2017 4:56 am
I am confused. Can you confirm again about mixture screw setting:
- Counter clockwise (loosing out): leaner.
- Clockwise (tighten in): richer.
The internet seems to say the reverse?
I am having problem of misfiring at cold start in morning, I guess it might be rich mixture problem so trying changing the screw setting day by day but till now it is just worse.
 Post Posted: Sun Feb 26, 2017 1:46 am
what i have done is, clockwise all the way in(DON'T make it too tight, you would break the tip)
then counterclock 2.5 rounds out
thats what i have all 4 carbs
try quality grade of gasoline... like Oct.95 :D
 Post Posted: Sun Feb 26, 2017 9:43 am
Different models have different settings. Check the workshop manual for your specific model.
I am talking about the 600 of course :angel
 Post Posted: Tue Mar 07, 2017 11:09 am
My carbs are original (Keihin VP03 or VP05), I guess. Can you please comment?
