Board index » Hornet 250 » Consumables
Post new topic Reply to topic  [ 11 posts ]
 Post Posted: Sun Oct 09, 2011 11:47 am
hi guys,
bought an aftermarket bmc airfilter because my stockfilter is very2x dirty, i would have bough K&N but opted for bcm to try it out
BMC Air Filter 206/12 Performance
i think is a race filter and my hornet is stock, after change the pipe sounds leaner, when i accelerate from first gear its like its bogging down, when it gets past 4k rpm it runs fast and pickup is great.
will adjusting pilot jet makes it richer on low rpms? or does it affect high rpm's too?
or do i need bigger jets?
 Post Posted: Sun Oct 09, 2011 12:11 pm
I have installed the same BMC filter. No real problems here. But I also noticed sometimes acceleration isn't quite smooth on full throttle from low revs. I plan to clean and sync the carbs soon. Hope this can resolve the slight problem.
 Post Posted: Sun Oct 09, 2011 12:41 pm
well thats the first hting i noticed,stock oem filter is better on low rpm really, sounds and revs better, even on neutral when i rev it i feel theres too much air
bmc also on high gears and low rpm 4-5k ish rpm is sluggish
so i think its on low rpm's only, high rpm no problem, angry and fast
my bike was synched before i installed the bmc
do i need to oil it? because its not on the box
 Post Posted: Sun Oct 09, 2011 1:20 pm
reiluke wrote:
...my bike was synched before i installed the bmc
I'll let you know if re-syncing changes anything, as soon as I have done it.
AFAIK you only need to oil the BMC filter after you washed it... maybe every 20,000km.
 Post Posted: Thu Oct 13, 2011 9:32 am
sup man, did you sync your bike yet? i did try to turn the pilot screws but cylinder 3 is very hard to reach
btw is that ur bike in your avatar? how much does that slash guard cost
 Post Posted: Thu Oct 13, 2011 12:42 pm
No, havn't had time yet. Actually I wouldn't really try the syncing myself. I would bring the bike to my local trusted service shop.
Also, I havn't noticed that sluggish accelleration problem again recently. Might have been some bad fuel or something... maybe some moisture in the fuel line or carb?! Anyway, I'll bring the bike over to the shop soon. ... Very busy these days...
Yes, that's my bike. If I remember correctly the splash guard cost me NT$170 (US$5.50) at a local scooter shop. It's from a SYM "Fighter 150", probably a Taiwan-specific scooter model. I cut off some part at the top and fitted it to what was left of the original splash guard on my bike. I was tired of having a dirty backside everytime when there was some water or dirt on the road. This thing works very well and keeps the tail light clean as well. Doesn't look too bad either, or?! :o
Image Image
 Post Posted: Sat Oct 15, 2011 11:51 am
you can also fit washers under the carb needles !
similar to this http://www.nighthawk750.com/mods/carbneedlemod.html
 Post Posted: Sat Oct 15, 2011 1:21 pm
Thanks for the cool link! I posted it in the DIY Guide section as well.
 Post Posted: Sat May 26, 2012 11:46 am
This week I finally got the carbs cleaned and synchronised. Still using the same BMC air filter. It's still looking very clean. Now the engine is much more responsive and revs smoothly to the redline. So I guess it's best to get the carbs cleaned and tuned right after you change to any non-stock air filter.
 Post Posted: Wed May 30, 2012 2:53 pm
i did carb and synchro'd but the mechanic still adjusted the airscrew from 2.5 to 2.0, now its all good
 Post Posted: Thu May 31, 2012 12:51 am
I've lost $95 usd in a poker game, should have just tuned up the bike, like what you guys did...
