Post new topic Reply to topic  [ 12 posts ]
 Post subject: Throttle cables
 Post Posted: Sat Oct 15, 2011 8:58 pm
Dear all,
The 'push' throttle cable on my CB250 '98 has snapped. Are the throttle cables for the 250s the same as those for the CB600s? Is the push cable the same as the pull cable?
Ps: lets not turn this into a cables cant push thread like all the others.
Thank you,
Olly
 Post subject: Re: Throttle cables
 Post Posted: Thu Nov 10, 2011 6:00 am
riding only with the pull cable is possible ?
 Post Posted: Fri Nov 11, 2011 2:58 am
or resolder
 Post Posted: Thu Dec 15, 2011 5:32 am
Hey mate, ya have 2 cables, one is ya throttle cable and the other is your (throttle return cable), you can use any hornet 250 cables or do what i do and go to wreckers and buy the cbr250rr cables as they are the same, i paid approx $30 nz 2nd hand for both cables from wreckers, as buying a new throttle return cable would cost $120nz. so just find compatable throttle setup(i.e take old 1 in and match it to new 1) and your away. you can ride without it but its recommended to have both because if you dont have it and your throttle sticks you have no control to shut carbies.
hope it helps
SpAzTeK
Chaos on 2 wheels
 Post Posted: Sat Mar 24, 2012 4:26 pm
my return cable is already busted when I got my bike... planning to replace both of them... but they are expensive..
will try to get a match from other bikes...
 Post Posted: Sat Mar 24, 2012 5:47 pm
Olly wrote:
Dear all,
Thank you,
Olly
You dont list where you live but here in the UK you can either buy the genuine or if Venhill eng http://www.venhill.co.uk/ dont list your cables all you have to do is post the old ones and they can at a push turn them round in 72 hours. They have done this with made to measure race cables for us in the past Oldgit
 Post Posted: Tue Jul 30, 2013 12:19 pm
[quboughtpaztek69"]Hey mate, ya have 2 cables, one is ya throttle cable and the other is your (throttle return cable), you can use any hornet 250 cables or do what i do and go to wreckers and buy the cbr250rr cables as they are the same, i paid approx $30 nz 2nd hand for both cables from wreckers, as buying a new throttle return cable would cost $120nz. so just find compatable throttle setup(i.e take old 1 in and match it to new 1) and your away. you can ride without it but its recommended to have both because if you dont have it and your throttle sticks you have no control to shut carbies.
hope it helps[/quote]
I bought two CBR 250 cables, they're far too short for my hornet 250
 Post Posted: Sat Aug 10, 2013 5:08 pm
any idea about the length of outer and inner cable for our push and pull cables?
 Post Posted: Sun Aug 11, 2013 9:32 am
Olly wrote:
Dear all,
Thank you,
Olly
1. Go to FAQ/How to
2. Download the PDF Parts Book
3. Search for the Throttle Cables
4. Write down that code/number
5. Search the internet for it or go into your local Honda dealership and ask for it.
 Post Posted: Wed Aug 14, 2013 7:29 am
throttle cable - outer cable 32 inches... inner cable 37 inches
 Post Posted: Wed Aug 14, 2013 6:43 pm
:clap
Proud owner of a Pearl Shining Yellow CB600F (2000)
Half the wheels, double the fun!
 Post Posted: Sun Aug 18, 2013 12:28 am
gonna look for some cables with same size...as long as they will fit and will give good throttle response it should work alright... honda parts are quite hard to find here in P.I. if ever you found one it will be expensive...
