Post new topic Reply to topic  [ 13 posts ]
 Post subject: tyre pressures
 Post Posted: Thu May 31, 2012 9:59 am
hi guys my hornet 250 has bridgestone battleax hyper sports on it and wonder wat best pressures for em as they feel rock solid yet the front is only saying 27 and rear 31 it is out the gauge but dno by how much n i dnt wanan pump them more cos they might blow as they feel rock solid pumped up.
 Post subject: Re: tyre pressures
 Post Posted: Thu May 31, 2012 11:11 am
The Hornet 250 manual says...
front: 225kPa / 2.25Bar / 33psi
rear: 250kPa / 2.50Bar / 37psi
But check the numbers on your tyres. Maybe the manufacturer suggests slightly different pressure values.
I usually pump between 36 and 38psi on the front, 40 and 42psi at the rear.
 Post Posted: Thu May 31, 2012 12:12 pm
ok tht sounds really high when the tyres already feel fully pumped up but ill try it. forgive my paranoia lol im alwasy too safety concious when everytihngs really ok :lol
 Post Posted: Thu May 31, 2012 5:30 pm
you will also need to consider your body weight...
for me I'm using 33 front and 38 psi on rear
I'm about 70 kilos
 Post Posted: Thu May 31, 2012 5:45 pm
I'm about 70 kilos
You can pump more air in... im about the same weight... i do 36 front and 42 Back...
remember the brakes and handling work best when the tires are inflated well... makes a noticeable difference
 Post Posted: Thu May 31, 2012 6:18 pm
that's the recommended pressure for my pirelli diablo corsa tires... but I wanted to have a softer ride.. I will try 35 and 40 next time
 Post Posted: Fri Jun 01, 2012 8:17 am
yea im about 78kg. and form wht i mreadiny u post even thou the tyres feel full on rock hard they can stil ltake alot more pumping
ill admit my foot pump isnt tht accrate so it could ready b higher then it is
 Post Posted: Fri Jun 01, 2012 10:52 am
right i looked at tires n it says max load 42 at both ends???? so i guess i could try a 32 and 36 i just dno if they burst as they feel rock solid
 Post Posted: Fri Jun 01, 2012 5:21 pm
No they wont burst.. dont worry....
Today my bike wasnt moving well... takes alot of Revs to get me going... so i went to gas station to check my Air and F*$% me it was 12psi :blast ... i was wondering how this happened and i then found a Nail :Bang sticking out... trust me with 12psi... the tyre still felt hard..
got to the tyre shop... pulled the darn thing out (2 inches of it) and then put a temporary puncture... Looking forward to ironing the insides over the weekend... there goes more money...
So ya... you can go all the way to 42... no probs... but nothing more than that
 Post Posted: Fri Jun 01, 2012 6:22 pm
thnsk tht helped my nerves massive it just my cbf125 at mo the lsighest loss of pressure n u can easily press on it n it feel soft but ok ill pump as much as i can :angel
 Post Posted: Sat Jun 02, 2012 4:48 am
This is so true remember my thread about 13 kilometers per liter?
My tire pressure was at 15 psi, m gonna check my tires on monday
 Post Posted: Sat Jun 02, 2012 4:50 am
Go to a gas station with air compressor for inflating tires
 Post Posted: Sat Jun 02, 2012 8:46 am
will do im sure there more accurate to
