Author |
Message |
Thenura
Posted: Wed Sep 26, 2012 4:31 pm |
Hornet Warrior |
i checked the charging voltage of my Hornet 250..it gives 14.45v maximum at about 8000 rpm .is it normal ? . i saw that battery has been swelled a bit. and one of the signal indicator bulbs blown and the bulb in the speedometer was blown yesterday .. i have put new bulbs.. but will the other bulbs blow too ? .. in the future ? .. what can be the problem ?
venomafiax
Posted: Wed Sep 26, 2012 4:48 pm |
Hornet Warrior |
Joined: Tue Jun 14, 2011 1:01 pm Posts: 387 Location: Colombo
A swollen battery is a bad sign... If i were you i would disconnect the battery and replace the battery immediately. I would save my electrics. It can affect your CDI and cause more serious damage.
_________________ ***Motorcycles have a SOUL..... and to create them is a work of pure Passion ~ MV Augusta~
Thenura
Posted: Wed Sep 26, 2012 5:10 pm |
Hornet Warrior |
bro mechanic said that it should be the regulater rec.... what do u think ?
venomafiax
Posted: Thu Sep 27, 2012 6:37 am |
Hornet Warrior |
it could be either the regular rectifier or the battery.. the only way to check is through trial and error... check what the output from the regular rectifier is.
Thenura
Posted: Thu Sep 27, 2012 3:43 pm |
Hornet Warrior |
how do i check it bro ? i meant the procedure
forcemajeure
Posted: Thu Jun 27, 2013 12:41 am |
Hornet Lord |
Joined: Wed Mar 21, 2012 7:46 pm Posts: 681 Location: Manila, Philippines
wow this thread has like 6009 views...!
