Board index » Hornet 250 » Consumables
Post new topic Reply to topic  [ 6 posts ]
 Post subject: Problem with the Battery
 Post Posted: Wed Sep 26, 2012 4:31 pm
i checked the charging voltage of my Hornet 250..it gives 14.45v maximum at about 8000 rpm .is it normal ? . i saw that battery has been swelled a bit. and one of the signal indicator bulbs blown and the bulb in the speedometer was blown yesterday .. i have put new bulbs.. but will the other bulbs blow too ? .. in the future ? .. what can be the problem ?
 Post Posted: Wed Sep 26, 2012 4:48 pm
A swollen battery is a bad sign...
If i were you i would disconnect the battery and replace the battery immediately. I would save my electrics. It can affect your CDI and cause more serious damage.
 Post Posted: Wed Sep 26, 2012 5:10 pm
bro mechanic said that it should be the regulater rec.... what do u think ?
 Post Posted: Thu Sep 27, 2012 6:37 am
it could be either the regular rectifier or the battery.. the only way to check is through trial and error... check what the output from the regular rectifier is.
 Post Posted: Thu Sep 27, 2012 3:43 pm
how do i check it bro ? i meant the procedure
 Post Posted: Thu Jun 27, 2013 12:41 am
wow this thread has like 6009 views...!
