Post new topic Reply to topic  [ 7 posts ]
 Post Posted: Fri Nov 16, 2012 11:20 pm
do you lube or grease your cables?
if yes which is much better to use? lithium grease or engine oil or gear oil?
 Post Posted: Sat Nov 17, 2012 1:25 am
I use engine oil bro, tie a celophane with some oil at the top end and wait for an hour or 2 to get it all lubed
 Post Posted: Sat Nov 17, 2012 2:04 am
1st clean those cables,
* disconnect them from levers and other ends
* pour some kerosene or gasoline in to cables
* then use some thick engine oil, 20w50 or 40w.. (i use new engine oil)
i am sure grease won't go all the way to the end of the cable that's why you should use oil
 Post Posted: Sat Nov 17, 2012 5:04 am
thanks reiluke and kane... will definitely lube those cables... will use engine oil as well
 Post Posted: Sat Nov 17, 2012 11:07 am
iF your cables are teflon lined then No you dont need to lube them.
Cables from Venhill eng who make after market cable here in the Uk are teflon lined and you can litteraly tie them in a not and they work perfectly. We have used them for several years racing and no problems. Oldgit
 Post Posted: Sun Nov 18, 2012 2:43 pm
Oem honda cables only, but thanks for the idea...
 Post Posted: Thu Jun 27, 2013 12:27 am
any idea about the inner and outer lenght of all the cables? clutch, throttle, choke?
