Post new topic Reply to topic  [ 12 posts ]
 Post subject: Hornet 250 engine oil
 Post Posted: Sat Feb 23, 2013 4:55 am
Hey guys I have a hornet 250 and want to do an oil change.
I live in Sri Lanka, I called AMW to ask them what type of oil they had, they said they have 10w40 Multigrade oil.
Can someone please explain to me what multigrade oil is.
And is it good for the motorcycle ?
 Post Posted: Sat Feb 23, 2013 5:06 am
Pretty much all engine oil is multigrade. Any oil that has the two number name like 10w-40, is multigrade.
It's a mixture of different oil molecules that behave in slightly different ways giving better performance at a range of temperatures. The mixture contains oils that keep their viscosity at low temps and other that keep it at higher temps.
Or something like that...
 Post Posted: Sat Feb 23, 2013 5:09 am
So will it be ok if I change my engine oil to multigrade ?
And is multigrade semi synthetic, fully syn or magnatec ?
 Post Posted: Sat Feb 23, 2013 5:14 am
Yes it will be fine.
"Pretty much all engine oil is multigrade". Meaning I would pretty much guarantee that the engine oil you are using is multigrade oil. I've never even seen engine oil for sale that isn't multigrade.
Or to put it another way, the engine is designed to use multigrade.
Whether it is synthetic, mineral or a semi has nothing to do with it. But Semi-synth is about as good as you'll ever need unless you are tuning or racing.
 Post Posted: Sat Feb 23, 2013 5:17 am
Whether it is synthetic, mineral or a semi has nothing to do with it. Semi is about as good as you'll ever need unless you are tuning or racing.
Ok thank you :)
 Post Posted: Sat Feb 23, 2013 5:20 am
Just one more question.
Are multigrade oil semi synthetic, fully syn or magnatec ?
 Post Posted: Sat Feb 23, 2013 5:22 am
All of them.
All oil is multigrade. There is synthetic multigrade, mineral multigrade... I don't know what magnatec is... is that a brand?
 Post Posted: Sat Feb 23, 2013 5:23 am
crumpy wrote:
All of them.
Oh now I get it. Thank you .
And how often should I chane multigrade oil ?
 Post Posted: Sat Feb 23, 2013 5:25 am
JeStEr wrote:
crumpy wrote:
All of them.
Ignore the word multigrade. As far as you need to know, all engine oil is multigrade oil. Anything else may as well be cooking oil. Change the oil as often as you think you should, the service schedule is a good start. 6000 miles is average for most bikes. I do mine a bit more because i thrash the living shit out of my bikes.
 Post Posted: Sat Feb 23, 2013 5:26 am
crumpy wrote:
JeStEr wrote:
crumpy wrote:
All of them.
Ignore the word multigrade. As far as you need to know, all oil is multigrade oil. Anything else may as well be cooking oil. change the oil as often as you think you should. The service schedule is a good start. 6000 miles is average for most bikes.
Ok i'm done thank you so much :D
 Post Posted: Sat Feb 23, 2013 5:27 am
My pleasure
 Post Posted: Sat Feb 23, 2013 9:36 am
I'm happy for you that you found help here in the forum, JeStEr. But please use the search function on the board first or even google a bit before you post your questions. Some things are not as complicated as they seem at first. ;)
Please also do not double-post or post questions in the FAQ section. I deleted your topic there, as it was an exact copy of this one.
Thanks to crumpy for the explanations above!
