Post new topic Reply to topic  [ 4 posts ]
 Post subject: Sprocket Removal
 Post Posted: Thu Jul 17, 2014 6:01 pm
Just a quick question as this will be the first time I've ever replaced a chain and sprockets.
Which way should I be turning the front sprocket nut to remove it? clockwise or counter-clockwise?
Also should I use some loctite on the rear sprocket's bolts?
 Post subject: Re: Sprocket Removal
 Post Posted: Thu Jul 17, 2014 11:28 pm
undo anti clockwise, as for the rear sprocket nuts just a small drop of thread lock should do the job. oldgit919
 Post Posted: Fri Jul 18, 2014 4:33 am
Thanks mate.
 Post Posted: Sat Aug 02, 2014 6:22 pm
use a long steel tube to help you out with the removal, you will have more leverage if you use a long round steel tube, insert the wrench on it
then used a wood block on the rear rim / tire, don't put the bike on gear
