Post new topic Reply to topic  [ 93 posts ]  Go to page Previous  1, 2, 3
 Post subject: Re: My Hornet Diary
 Post Posted: Fri Jul 15, 2016 9:04 am
Great! - looking forward to seeing the pics :D
 Post Posted: Thu Sep 08, 2016 4:17 am
Here you go
Fogs with devil Eye
Airhorn
 Post Posted: Thu Sep 08, 2016 4:50 am
Led headlight (low only) :cry
 Post Posted: Thu Sep 08, 2016 4:54 am
Full Set
 Post Posted: Sat Sep 17, 2016 2:35 am
Update: 2016/09/17
Flushed cooling system completely including reservoir tank and next day filled it with fresh green wurth coolant and distilled water
almost 2L for everything 8o
 Post Posted: Wed Oct 19, 2016 2:29 am
Oil Change with Filter
Oil Type: 10w40 Motul Easter Core (3L Cost 11,400LKR) its getting expensive :(
Oil Filter: Made in Japan
ODO: 45,000KMs
* would you believe that our mechanics still pour whole 3L in to the engine? :eek
my engine cover has a tiny sticker, it says
after engine rebuild 2.7L
With oil filter 2.4L
without filter 2.2L
i wonder what could happen when you pour 3L in to??! :help
But i didn't let him to do to me, i bought 0.6L with me (Perfect stuff to lube O ring chain) :thumbup
 Post Posted: Mon Nov 28, 2016 3:25 am
Update: 2016/11/24 Sprockets and Chain Change
ODO: 46000Kms
Front: 14T Genuine
Rear: 52T SuperSprox Stealth
Chain: 520 D.I.D 120L Oring Gold
Crash Bobbins(Came Red but Painted to Mate Black)
Note: Almost 30000Kms With Genuine Sprocket Kit and DID Gold Oring :clap
Pics Soon
 Post Posted: Sun Dec 10, 2017 2:58 am
Update: 2017/12/10 Oil Change
ODO: 52000KMs :Bang
Oil: Motul 10w40 300V 3L (11450LKR)
Oil Filter: Genuine with Rubber Washers/Seals
Airfilter: Cleaned
Pic:
 Post Posted: Sun Dec 10, 2017 11:40 am
Love the fogs :love :D
 Post Posted: Fri Feb 23, 2018 3:12 am
after i got this, no need of Fogs so i removed them, it did drain bat. power a lot :(
 Post Posted: Fri Feb 23, 2018 4:24 pm
Hi Kane - did you wire the fogs up directly to the battery? If so that may be the reason for the power drain - the fogs might have been drawing power even with the bike switched off.
If you wire the fogs into the existing lighting circuit then they should only get power when the main light is switched on (unless you wire a separate fog light switch into the lighting circuit so you can switch the fogs on/off independently of the headlight.
 Post Posted: Sat Mar 10, 2018 10:50 am
mm yeah thats what the manual said, so i wired it to th bat. and a relay...
without the relay, fog may generate low light?! 8o
ah no no.. fogs did get a direct line from the bat. but it was connected to the headlight and it had an independent switch
headlight had to be in Hi mode to power up fogs and turned on that switch. everything went off when i turned ignition switch off
 Post Posted: Sun Mar 11, 2018 1:50 pm
Hi Kane,
It is possible to perform a 'parasitic draw test' with a multimeter to see if the lights are draining power with the bike switched off - if you establish that the lights are drawing power and running the battery down you can then rewire the lights to prevent parasitic power draw.
Users browsing this forum: No registered users and 3 guests
