Board index » Hornet 600/599 » General chat
Post new topic Reply to topic  [ 8 posts ]
 Post subject: Cheap rectifier?
 Post Posted: Wed Aug 07, 2019 6:50 pm
Good rectifier?
https://rover.ebay.com/rover/0/0/0?mpre ... 1397180737
Seems to be a SHINDENGEN?
 Post subject: Re: Cheap rectifier?
 Post Posted: Thu Aug 08, 2019 7:30 am
Yeah - it's a Chinese reg/rect - I bought one for my bike - unfortunately I haven't used it yet so I can't say if it's any good - but after checking out a few bike forums most people seem to be getting good results from them - I'm gonna wire in a volt meter as well so I will be able to see how it is performing and hopefully get a heads up before my battery runs down if it does crap out.
You can do a test on it with a multimeter to check it's working properly before you fit it - the info is on youtube.
There is a good selection on Amazon:
https://tinyurl.com/y3eutdxw
 Post Posted: Thu Aug 08, 2019 9:40 am
I thought the SHINDENGEN was the original part? Is the original what I should get?
 Post Posted: Thu Aug 08, 2019 12:20 pm
Yeah - sorry - my mistake - Shindengen is the Japanese original part - so if it is as described it should be fine.
Some people upgrade their reg/rect from the stock item - e.g. MOFSET
 Post Posted: Thu Aug 29, 2019 4:11 am
I have never had a regulator failure, but mine is one of the finned “SH” Shindengen ones like the OP pictured.
Due to a weird issue with my CDI (spark unit), I have decided to upgrade to the mosfet “FH” Shindengen regulator/rectifier as discussed here way back when.
I ordered an eBay part from a 2005 Kawasaki ZX10. It has the same 5 connections, but will just need a new mounting hole it seems as it’s slightly wider.
Example: https://www.ebay.co.uk/itm/Kawasaki-ZX10R-2004-2005-C1H-regulator-rectifier/143356963867?epid=16027015357&hash=item2160bdac1b:g:GEUAAOSwglJdVYUq
Silver 2000 CB600F, Danmoto Titanium, Iridiums, K&N, jet kit, 15/45 Sunstar, Metzeler Sportec M5, stainless lines, prog. fork springs, custom hugger, DIY fenda extenda, LED tail light, LED front turn signals, mirror mounted LED running lights, polished rims, Givi screen, chromed down pipes...
 Post Posted: Thu Aug 29, 2019 11:44 am
yep, just need to drill a new hole, i fitted one a few years back, big improvement, never had a problem again with charging voltage :)
 Post Posted: Thu Aug 29, 2019 2:20 pm
Thanks Steve, I knew I read how you did the MOSFET reg/rec upgrade in your fun in the shed thread! Your work and advice are always top notch!
Thank you!
:clap
 Post Posted: Thu Aug 29, 2019 3:34 pm
I did the same, a while after Steve paved the way.
http://www.hondahornet.org.uk/messageboard/viewtopic.php?f=60&t=32844&hilit=shindengen#p283210
Users browsing this forum: No registered users and 5 guests
