Post new topic Reply to topic  [ 7 posts ]
 Post subject: H4 LED "flashing "
 Post Posted: Fri Sep 14, 2018 6:54 pm
i buy i H4 LED for my motorcyle and when the moto is on neutral the led blinks very fast ( like there as if he did not have enough energy) when i it the gas its give more light..
there is any way to fix this? thanks
 Post subject: Re: H4 LED "flashing "
 Post Posted: Fri Sep 14, 2018 8:14 pm
You need to fit a relay:
https://www.ebay.co.uk/bhp/motorcycle-flasher-unit
This guy explains why and how:
https://www.youtube.com/watch?v=HdERp5e78eM
 Post Posted: Fri Sep 14, 2018 8:27 pm
relay its not for the headlights its for the turning ligts .
my problem is on the healight H4
 Post Posted: Fri Sep 14, 2018 9:46 pm
Your new headlight is pulling more power (5 amps) out of your electrical system than the wiring (and possibly even the generator) was designed to cope with (around 3 amps) - fit thicker wire from battery to headlight to offset the voltage drop.
 Post Posted: Fri Sep 14, 2018 10:08 pm
no good.i have to put some resister or capacitor
 Post Posted: Fri Sep 14, 2018 10:14 pm
Is your battery fully charged and in good condition?
 Post Posted: Sat Sep 15, 2018 9:46 am
Quick search found this.. (I have no experience with LED headlights... so can't recommend)
If your headlight flickers you will need to install a load resistor. You can find this at any electronics store. The value of the resistor which I found to work best for me is 500 ohms, you can try other values to see which work best for you. Good luck,
PS. Install the resistor between the two lines going to your headlight, on the car harness.
Or simply fit an bulb as I've done.
