Board index » Hornet 600/599 » Mechanical & Electrical
Post new topic Reply to topic  [ 1 post ]
 Post subject: Front brake cb600fa7
 Post Posted: Sat Aug 05, 2017 4:31 pm
Front left Caliper bracket has more play than right side, and I mean on the bottom slide stud. There's a fair bit of play but nothing can wear because of the rubber boot. I've put a new rubber in and greased it and it's a bit better but still a lot of play compared to the other side there's also a 0.3mm difference in the stud size diameter compared to the right side, is a 2007 abs 600. Just wanted to check if that's normal, cheers
Users browsing this forum: Google [Bot] and 1 guest
