Board index » Hornet 600/599 » Consumables
Post new topic Reply to topic  [ 9 posts ]
 Post Posted: Tue Sep 10, 2019 9:51 pm
i have a heated grips to connect, i usually connect directy to the battery. but i allways to forget to power off grips.
anyone knows how i connect directly to the moto? only works when the moto is working ( key is on start )
thanks in advance
 Post Posted: Thu Sep 12, 2019 1:44 pm
canĀ“t anyone help?
 Post Posted: Thu Sep 12, 2019 11:02 pm
all the oxford heated grips i have owned have had a built in function that turns off buy itself. I think it turns off buy a sensor that see`s voltage drop on the battery, but im not sure of this.
 Post Posted: Fri Sep 13, 2019 3:26 pm
mine its a simple on, ebay under 10 bucks
works like a charm but i forget many times to power it off :blast
 Post Posted: Sat Sep 14, 2019 7:47 am
You need to find a work-relay and connect your heated grips via this. That way, you can use a consumable (such as your lights) to control your relay and connect the grips directly to the battery.
 Post Posted: Sun Sep 15, 2019 9:38 pm
can i connect here?
 Post Posted: Fri Sep 27, 2019 4:17 am
anyone?
 Post Posted: Fri Oct 11, 2019 10:02 am
There is a link to the workshop manual on here, that will have your wiring diagram and show you which wire for the ignition circuits can be spliced into for a relay to your grips.
Colgster
 Post Posted: Sat Oct 12, 2019 9:11 am
Sorry - I haven't been on for a while. As I wrote earlier, I would buy a working relay and connect the heated grips directly to the battery (through the relay) and use a "ignition-on" wire to control the relay (could be rear light fx) . This way you will not end up drawing to much current through the existing wiring.
Something like this:
https://www.ebay.co.uk/itm/12V-Automoti ... SwXXxZVgha
