Board index » Hornet 600/599 » Consumables
Post new topic Reply to topic  [ 4 posts ]
 Post Posted: Wed Dec 04, 2019 9:48 pm
New float bowl gaskets are on the list of what needs to be changed this winter. Brake lines as well.
You guys think I should change anything else while inside the carbs? Any seals or orings that should be replaced?
I'd also like your opinion on the HEL braided brake lines. Are they the best for the money?
Cheers
 Post Posted: Wed Dec 04, 2019 10:40 pm
Hel are very good quality 8o
 Post Posted: Thu Dec 26, 2019 8:36 am
When you have the carsbs off, I would make sure to clean all jets, and possibly change the float neele as well - usually you can get a carb repair kit that includes both gaskets, float needle and o-ring for this, like:
https://www.ebay.co.uk/itm/223710981278
 Post Posted: Sat Dec 28, 2019 3:44 pm
I have wezmoto and they are fine. I have read somewhere that they're basically the same as hel (same materials and process, just different name), not sure how true that is though.
I went for wezmoto back then because they were slightly cheaper than hel and have had no issues with them so far
