Board index » Hornet 900/919 » Mechanical & Electrical
Post new topic Reply to topic  [ 2 posts ]
 Post Posted: Tue Jul 16, 2013 3:52 pm
GGOTW Winner
Well, was I happily amused this afternoon!
So I reads the 900 service manual and it says to lift tank and then loosen rad and pull forward. Well, I lifted tank, secured it with a small tub of plumbers putty... did not loosen rad. The left side was a doodle in the park. Both plugs out in a moment. Next is the right side. loosen the rad fill cap assy off the frame (small Phillips) and loosen the under coil. Another 5 mins and the plugs are swapped. The only awkward part is the inside right plug as the water hoses interfere with the socket wrench - but not too bad. A job done in 15 mins.
Compared to the 600, I WISH THE TANK COULD BE RAISED!!!!!! The 600 you gotta take all the hoses off the tank, remove the left ignition coil. In all a job takes at least 1/2 hour min. (It's the replacing of the tank hoses and tank removal that takes the time.
Yup... I gotta get out more! :angel (Probably got a ticket on A23 y'day... !)
 Post Posted: Sun Jul 21, 2013 6:24 pm
I've both cleaned multiple times and changed the plugs on my 6er.
The only thing that needs doing is removal of the fuel tank.
And then reconnecting the main + reserve fuel hoses.
Takes 15min.
Yes I do have large hands, the only tricky plug is the nr3? (3rd from the nearside) Which happens to be just below the reg/rec.
I don't use a socket wrench for that though, well not the entire wrench.
Just the spark plug bit - the end that attaches to the actual socket wrench - without using the wrench.
And simply twisting it with my fingers to tighten/loosen.
Then take some bluetac and put it at the end of the spark plug bit, and fish out the plugs.
Job done. :hat
