Board index » Hornet 900/919 » Mechanical & Electrical
Post new topic Reply to topic  [ 19 posts ]
 Post subject: Fuel pump faulty !!!
 Post Posted: Mon Nov 28, 2016 5:33 pm
I think the bloody fuel pump is on its way out , on several occasions now I turn key , all dash lights come on , HISS light goes out ,fuel relay clicks , yet no priming of the fuel pump and she wont start :Bang
Anyone had this happen to them ?
Looks like the fuel pump is sealed unit , Honda price £500 !!! 8o 8o ,, weemoto pattern part £150, Ebay £100 ( MandP)
Anyone got a spare 900 fuel pump :angel :angel
 Post subject: Re: Fuel pump faulty !!!
 Post Posted: Mon Nov 28, 2016 6:38 pm
Try the plug with two wires under the fuel tank. I might have a spare pump in my box of spares. Will look a bit later.
 Post Posted: Mon Nov 28, 2016 7:37 pm
Thanks Daryl, as always your a star mate :clap :clap
UPDATE !
I just came in from the garage, after some more researching on the web , and turned my attention to the fuel pump relay,
Bare in mind battery is new and is giving 12.8 v ,
So I just been out with my meter and ran a wire from the prime pump live feed wire to my meter +ve probe and the other probe to earth
I turned key and the reading was barely 11v, and fluctuating down to 10v, im thinking this is not enough volts to prime the 12v pump correctly.
I then located the fuel pump relay, under the seat, and I notice there is x3 relays all the exact same spec, so I swapped one over with the suspected faulty fuel pump relay
Turned key and BOOM , the fuel pump immediately springs into life with a really lively whirring sound , not usually heard :angel
Voltage reading 12v constant.
So im hoping that's it , I hope the circuit I swapped with is not so crucially dependant on the unwell relay, as I commute everyday , and will order a new relay asap
So fingers crossed I just need a new 12v NO RC-2208 MITSUBA relay
This relay is from Honda is 8o 8o 8o
PFKL561816
RELAY COMP., STARTER (MITSUBA)
£37.60
or £2.29 from ebay for a 30a 12v No relay, and abit of soldering of wires !!
http://www.ebay.co.uk/itm/12V-Relay-5-PIN-Automotive-30AMP-30a-Changeover-RY7-Detachable-Bracket-/111581021341?hash=item19fabf449d:g:wOYAAOSwDNdV6WVm
 Post Posted: Mon Nov 28, 2016 8:09 pm
Nice cheap fix is always good :clap
If you do get stuck for a fuel pump I do have a spare.
 Post Posted: Mon Nov 28, 2016 9:45 pm
For an electrical problem you diagnosed and sorted that out nice and quick - I'm impressed. :clap
 Post Posted: Mon Nov 28, 2016 10:19 pm
thanks daryl :thumbup
 Post Posted: Mon Nov 28, 2016 10:21 pm
thanks Hoon, although I should admit , I am a qualified sparky and I started life as an electrical control panel systems engineer :angel
 Post Posted: Tue Nov 29, 2016 12:52 am
Lol! - so that explains it! :angel - I was starting to feel really inadequate and thinking 'blimey - how did he work that out?' :eek :D
 Post Posted: Tue Nov 29, 2016 10:32 am
:lol :lol
I just managed to find a 30a N/O relay in my garage , wired it up to the fuel prime circuit , turned on the ignition and it works great,
Result !!!
keep your £40 relay Mr Honda :finger
:angel
ps anyone reading this in the future who may need the wiring diagram , please let me know
 Post Posted: Fri Feb 03, 2017 11:01 pm
Argh, its back !!! :Bang
Leaving work today , turned ignition on , nothing , silence, after 10 attempts the fuel pump finally energised and started immediately , then , later on getting fuel the same again, sat on the bike trying to start it , with car drivers queuing behind :help
So guess what my weekend job is , :cry
Ive done some web hunting on this , and I get a few hits come back of -
Fuel pump
Fuel pump relay
ECM
Clutch switch
Side stand switch
Kill switch
Bad earth
What I have discovered so far,
Apparently the last 6 items above all rely on a good earth also to put a " GOOD TO GO" signal to the ECM , which in turn energises the fuel pump relay,,,
The bike has never cut out while riding, if it did , it wouldn't be ridden.
I hope its not the end of my 9er , shes on 30k miles now , and the engine is as sweet as a nut.
Any others ideas on this one is greatly appreciated :thumbup
 Post Posted: Fri Feb 03, 2017 11:30 pm
Connector under the fuel tank that goes to the fuel pump?
 Post Posted: Sat Feb 04, 2017 10:10 am
I checked that thanks mate, and the ground connection there, seems all good, its in a pretty protected area too, so no water or salt getting in there.
A few FI fireblades with the same issue if you google it also :Bang
 Post Posted: Sat Feb 04, 2017 12:45 pm
It's easy to pull the pump out of the bottom of the fuel tank if you want to look at that. No need to buy any gaskets for it if you do as I've had mine out a few times without issue.
 Post Posted: Sat Feb 04, 2017 7:58 pm
:thumbup
Today I removed the kill switch and stripped it down, it had old hard lube in it , removed it all and re-greased with light oil.
I have also removed the side stand switch connecter and shorted it out, to prove if the switch isn't making giving an intermittent contact.
Fuel pump is now priming , but its done this before , been ok for a few days then goes again.
The neutral switch is also involved in a " good to go " signal to the ECM, that in turns primes the pump, so will check this out also.
I will try and keep this going until I find a solution , as it may help someone else in the future if they get the same issue :)
below is a 900 ignition system diagram for those really interested :angel
 Post Posted: Sun Feb 05, 2017 1:22 pm
Update,
This am turned ignition and no fuel pump prime noise :Bang
I then checked the side stand switch circuit , and its good !! glad about that as its £65 for a new, 8o
I then turned to the " engine stop relay" which when energised, the fuel pump relay immediately energises after,
so I swapped the engine stop relay with my home made temp car relay just to see, and the fuel pump primed immediately, 8o
I have tested 20 times so far and the fuel pump primes immediately every time , have I found the issue ? did the fuel pump relay and the engine stop relay both have issues , they are identical relays ? do they have a life span ? abit like bulbs , when one goes the rest also go around the same time ?
Anyway , I will keep an eye on it all.
 Post Posted: Fri Nov 24, 2017 7:25 pm
.........................You have a pm Paul :D
 Post Posted: Sat Nov 25, 2017 10:42 am
thanks Daryl :thumbup
 Post Posted: Sat Dec 23, 2017 6:50 pm
Update !!!
After much investigation ,and a fuel pump complete strip down ( pumped looked good ) , then a chat with Daryl , we narrowed down to a potential issue with the HISS receiver aerial, the part that picks up the key code when the key is placed into the ignition and sends a good code signal to the ECU, then in turn the ECU activates the fuel pump, but with a bad code or no code to the ECU , the pump will not get a prime signal sent from the ECU
Daryl found me a Chinese seller from China on Ebay for the OEM HISS receiver , and I bought one for £10 posted .
3 weeks later it arrived and i fitted it , but when removing the clocks to remove the old HISS receiver i noticed a "pinch point" on the cable from the receiver, so i filed away some plastic under the clocks, all seems good so far.
Im currently off road now until spring ,so time will tell
thanks Daryl for your assistance :thumbup
 Post Posted: Mon Feb 05, 2018 6:24 pm
Hi Paul,
I am interested in any updates as one member at the german Hornet board reports the same issue. He has been to the dealer and they replaced nearly any expensive part (including the fuel pump) without any improvement. For the time beeing, he spent about EUR 1500 but the bike won't start. It is a low-mileage bike with only 12,000 kms on the clock.
There are three relay which are identical:
The left one is for the cooler fan. I would suggest to switch that one, not the one that stops the engine (which is the right one).
In my opinion, if the voltage is 11V, the problem is caused by a faulty relay. If any other part would be faulty, there would be no voltage at all at the fuel pump.
Cheers,
Michael
1998 CB600F PC34
2003 CB900F SC48
2001 CB500S PC32
1981 XL185S L185S
